A component that manages transmitting requests from internal management module applications to IO cards has detected that the request sequence number has wrapped. This condition indicates that thousands of events are pending transmition, and this almost certainly indicates a hardware failure.
Report the issue to your switch support contact.
Error
A request to send a message to an IO card was rejected because the maximum # of outstanding requests has been exceeded - sequence # %seqNo% seq. Ack. # %seqAck% , blade # %blade%, pipe # %pipe% and conduit # %condNum%.
| Name | Type |
| seqNo | uInt16 |
| seqAck | uInt16 |
| blade | uInt |
| pipe | String |
| condNum | uInt |
